T
totorolm@gmail.com
Guest
Hi,
I need to merge users home directories (traditionally /home) and
additionnal software (traditionally /usr/local) on a single partition
(which is not formated during system upgrade).
What would be the mount point of such partition ?
Could it be /usr/local ?
According to Wikipedia on Filesystem Hierarchy Standard:
/usr/local is a "Tertiary hierarchy for local data, specific to this
host. Typically has further subfolders, eg. bin/, lib/, share/."
So it seems to be the place to do it. But the problem is that /usr/
local/home seems strange: is not complient with the Filesystem
Hierarchy Standard
Thanks for your opinions/experience
Hierarchy Standard
