Home
Forums
Blog
Guides
User Guides
Tips
Tips 'n' Tricks
Error DB
Ask an Expert?
General Q&A
Hardware Support
Software Support
Log in
Register
What's new
Menu
Log in
Register
Install the app
Install
Home
Forums
Tech Support Archives
Microsoft
Microsoft Device Drivers
how to modify serial number of usb device by usb filter driver?
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
[QUOTE="Doron Holan [MS], post: 1016359"] [b]Re: how to modify serial number of usb device by usb filter driver[/b] you are proposing to write a bus filter driver. quite difficult to do and completely undocumented and unsupported by microsoft. d -- Please do not send e-mail directly to this alias. this alias is for newsgroup purposes only. This posting is provided "AS IS" with no warranties, and confers no rights. "curliph" <curliph@discussions.microsoft.com> wrote in message news:B23C1C69-1643-4E2D-8BB7-5D2970F53A34@microsoft.com...[color=blue] > You are right...I had just follow the advice by Maxim S. Shatskih. > it still can't work :( > > I will try to filter the entire bus...any advice? > or, Is there other way to make the two device work together? > > > "Doron Holan [MS]" wrote: >[color=green] >> that is too late. you need to filter the parent hub's query device >> relations. you need to filter the entire usb bus since you don't know >> which >> port you will be attached to. this is a very difficult task, you can't >> really work around your broken hw this way >> >> -- >> Please do not send e-mail directly to this alias. this alias is for >> newsgroup purposes only. >> This posting is provided "AS IS" with no warranties, and confers no >> rights. >> >> >> "Maxim S. Shatskih" <maxim@storagecraft.com> wrote in message >> news:uVRQ2TAkGHA.1324@TK2MSFTNGP04.phx.gbl...[color=darkred] >> > Add the filter which will just ignore the serial number by patching >> > the >> > DEVICE_CAPABILITIES and resetting UniqueId bit. >> > >> > -- >> > Maxim Shatskih, Windows DDK MVP >> > StorageCraft Corporation >> > [email]maxim@storagecraft.com[/email] >> > [url]http://www.storagecraft.com[/url] >> > >> > "curliph" <curliph@discussions.microsoft.com> wrote in message >> > news:BDBC08DD-BC5F-4382-819A-0DB6275D9197@microsoft.com... >> >> Thanks for your answer! >> >> Infect, I have two usb device with the same pid/vid and serial number. >> >> them can not co-exist in windows... >> >> for certain reason,I have to fix the bug by modify somthing inside >> >> os.. >> >> I think I should change the string of iSerialNumber before os load >> >> usbstor.sys. >> >> so,the changed value should be used by usb core or even lower drivers. >> >> right? >> >> but I don't know how to do that! >> >> >> >> >> >> "Doron Holan [MS]" wrote: >> >> >> >> > what side affect do you want your change to have? that the usb core >> >> > not >> > use >> >> > it for a unique ID or that usbstor uses your changed value ? >> >> > >> >> > d >> >> > >> >> > -- >> >> > Please do not send e-mail directly to this alias. this alias is for >> >> > newsgroup purposes only. >> >> > This posting is provided "AS IS" with no warranties, and confers no >> >> > rights. >> >> > >> >> > >> >> > "curliph" <curliph@discussions.microsoft.com> wrote in message >> >> > news:1683548F-03C7-4752-A1AB-8F8695509BA5@microsoft.com... >> >> > > hi, I want to modify the serial number or PID/VID of my usb mass >> >> > > stroage >> >> > > disk. >> >> > > I try it by an usb class filter driver to capture the >> >> > > URB_FUNCTION_GET_DESCRIPTOR_FROM_DEVICE,then modify the data... >> >> > > But,It seems useless! >> >> > > how should I do? many thanks! >> >> > >> >> > >> >> > >> >[/color] >> >> >>[/color][/color] [/QUOTE]
Insert quotes…
Verification
Post reply
Home
Forums
Microsoft
Top
