"Open links from other programs" option does not work
  • Thread starter arbitr@sbcglobal.net
  • Start date
YW. Sit tight. I believe a colleague knows a fix for this and I've asked
him to reply to the thread.
arbitr@sbcglobal.net wrote:
> Enabled on both XP & Vista.
> Thank You for trying to help...
>> PA Bear wrote:
>> Sorry about that, but if you'd included all of the previous conversations
>> in your replies, I might have caught it.
>> WinXP: IE Tools > Internet Options > Advanced > Browsing > Reuse windows
>> when launching shortcuts: Is this option disabled or enabled?
>> Vista: IE Tools > Internet Options > Advanced > Browsing > Reuse windows
>> arb...@sbcglobal.net wrote:
>>> Looks like You didn't get the question.
>>> Program works fine in Vista.
>>> Program doesn't work right in XP.
>>> There is really no point in going deep into Vista. I need help with XP/
>>> IE7 combo.
>>>> On Jan 18, 1:29 pm, "PA Bear [MS MVP]" <PABear...@gmail.com> wrote:
>>>> I think you need to become much more knowledgable about the enhanced
>>>> security features in Vista, including UAC (User Account Control),
>>>> Protected
>>>> Mode in IE, and Privileges.
>> <snip>
>>>>> Page is in regular Internet zone.
>>>>> 1. Do you understand the difference between IE opening a page and
>>>>> another application opening the page *using* IE? Yes
>>>>> 2. Do you understand Vista's enhanced security features including UAC?
>>>>> No.
>>>>> I'm looking into way to make program work consistently with IE7 in XP
>>>>> and Vista.
>>>>>> On Jan 18, 11:41 am, "PA Bear [MS MVP]" <PABear...@gmail.com> wrote:
>>>>>> [To keep track of things, it helps immensely if you include all of
>>>>>> previous
>>>>>> message(s) in your replies to the newsgroup. Thank you.]
>>>>>> And in what security zone is the page running?
>>>>>> another
>>>>>> application opening the page *using* IE? Do you understand Vista's
>>>>>> enhanced
>>>>>> ~PA Bear
>>>>>>> I try to open SAME web page.
>>>>>>> On Jan 17, 6:08 pm, "PA Bear [MS MVP]" <PABear...@gmail.com> wrote:
>>>>>>>> You're not running WinXP anymore.
>>>>>>>> If the open IE window is displaying a page in, e.g., Internet zone
>>>>>>>> and
>>>>>>>> the
>>>>>>>> page you want to open runs in a different zone, e.g., Secure Sites,
>>>>>>>> a
>>>>>>>> new
>>>>>>>> window is invoked by default.
>>>>>>>> If the open IE window is displaying a https:// page and you're
>>>>>>>> attempting
>>>>>>>> to open a http:// page, a new window is invoked by default. <paste>
>>>>>>>> arb...@sbcglobal.net wrote: I have a program which opens Internet
>>>>>>>> pages
>>>>>>>> in IE7. In Vista it opens new pages in tabs of single IE. In XP it
>>>>>>>> creates new IE window for
>>>>>>>> each page. "Open links from other programs" option in both cases
>>>>>>>> set
>>>>>>>> to "New Tab".
>>>>>>>> Please, advise.- Hide quoted text -
>>>>>> - Show quoted text -- Hide quoted text -
>>> IE7 combo.
>>>> Protected
>> <snip>
>>>>> No.
>>>>> and Vista.
>>>>>> previous
>>>>>> another
>>>>>> enhanced
>>>>>> ~PA Bear
>>>>>>>> and
>>>>>>>> the
>>>>>>>> a
>>>>>>>> new
>>>>>>>> attempting
>>>>>>>> pages
>>>>>>>> set
>>>>>>>> to "New Tab".
I disabled the *Tabs* in IE7 soon after getting it as I didn't care for
them. So, I don't know if this will help or not. Some people using IE6 & IE7
had the problem where clicking on a link opened IE without a problem, but
clicking on a second link reused the same window. the fix I have was to open
in multiple windows. Perhaps from this you can rearrange it as per the OP's
wishes.
To open and minimize more than one link in OE at the same time, first close
Outlook Express:
In Internet Explorer: Tools | Internet Options | Advanced. Uncheck: Reuse
windows for launching shortcuts.
Close all programs. In Windows Explorer, or the Control Panel:
Go to Tools | Folder Options | File Types.
Scroll down to {NONE} Internet Shortcut and select it.
Click Edit or Advanced, depending on your Windows version.
Select 'open'.
Click Edit.
Uncheck: Use DDE
Reopen OE and it should now open more than one link at a time.
Bruce Hagen
MS-MVP Outlook Express
Imperial Beach, CA
"PA Bear [MS MVP]" <PABearMVP@gmail.com> wrote in message
news:%23lO$lbnWIHA.5348@TK2MSFTNGP03.phx.gbl...
>>> conversations
>>>> IE7 combo.
>>>>> Protected
>>> <snip>
>>>>>> UAC?
>>>>>> No.
>>>>>> and Vista.
>>>>>>> previous
>>>>>>> another
>>>>>>> enhanced
>>>>>>> ~PA Bear
>>>>>>>>> and
>>>>>>>>> the
>>>>>>>>> Sites, a
>>>>>>>>> new
>>>>>>>>> attempting
>>>>>>>>> <paste>
>>>>>>>>> pages
>>>>>>>>> set
>>>>>>>>> to "New Tab".
Thanks, Bruce!
@arbitr: Substitute the program you're using to invoke IE for all references
to OE/Outlook Express in Bruce's reply.
IOW, the following might be your fix:
> Select 'open'.
> Click Edit.
> Uncheck: Use DDE
That last line is the crucial part.
~PA Bear
> IE7
> open
> OP's
> wishes.
> close
> Outlook Express:
> Select 'open'.
> Click Edit.
> Uncheck: Use DDE
>> asked
>>>> conversations
>>>> windows
>>>> windows
>>>>> XP/
>>>>> IE7 combo.
>>>>>> Protected
>>>> <snip>
>>>>>>> UAC?
>>>>>>> No.
>>>>>>> XP
>>>>>>> and Vista.
>>>>>>>> previous
>>>>>>>> another
>>>>>>>> enhanced
>>>>>>>> ~PA Bear
>>>>>>>>>> zone
>>>>>>>>>> and
>>>>>>>>>> the
>>>>>>>>>> Sites, a
>>>>>>>>>> new
>>>>>>>>>> attempting
>>>>>>>>>> <paste>
>>>>>>>>>> pages
>>>>>>>>>> it
>>>>>>>>>> set
>>>>>>>>>> to "New Tab".
Sorry, it didn't work.
Thanks for your help...
>On Jan 19, 11:21 am, "PA Bear [MS MVP]" <PABear...@gmail.com> wrote:
> Thanks, Bruce!
> > Select 'open'.
> > Click Edit.
> > Uncheck: Use DDE
> ~PA Bear
> > IE7
> > open
> > OP's
> > wishes.
> > close
> > Outlook Express:
> > Select 'open'.
> > Click Edit.
> > Uncheck: Use DDE
> > "PA Bear [MS MVP]" <PABear...@gmail.com> wrote in message
> >> asked
> >>>> conversations
> >>>> windows
> >>>> windows
> >>>>> XP/
> >>>>> IE7 combo.
> >>>>>> Protected
> >>>> <snip>
> >>>>>>> UAC?
> >>>>>>> No.
> >>>>>>> XP
> >>>>>>> and Vista.
> >>>>>>>> previous
> >>>>>>>> another
> >>>>>>>> enhanced
> >>>>>>>> ~PA Bear
> >>>>>>>>>> zone
> >>>>>>>>>> and
> >>>>>>>>>> the
> >>>>>>>>>> Sites, a
> >>>>>>>>>> new
> >>>>>>>>>> attempting
> >>>>>>>>>> <paste>
> >>>>>>>>>> pages
> >>>>>>>>>> it
> >>>>>>>>>> set
> >>>>>>>>>> to "New Tab".
Back
Top
