xorg.conf
On Thu, 06 Dec 2007 14:00:14 -0600, Moe Trin wrote:
> On Wed, 5 Dec 2007, in the Usenet newsgroup alt.os.linux.ubuntu, in article
> <1f3k5r.9k4.19.7@news.alt.net>, Meat Plow wrote:
>>Mark South wrote:
>>> find /etc -iname xorg.conf
>>~$ slocate xorg.conf works too
> slocate (and the original 'locate') consult a database of files usually
> created as a nightly cron-job. If your system isn't running at the
> scheduled time, and you are not running a part-time cron daemon like
> anacron or fcron, then the database won't be up to date. Thus it will
> report about files you have deleted, and won't know about files that
> have been created or moved since that database update. The 'find'
> command looks to see what is "there" now, and tends to be much slower
> than reading a pre-existing database (that was created by running
> find as part of that cron-job).
> Find can be made to run faster by (as here) limiting the area of the
> filesystem that is searched. This implies that you are somewhat familiar
> with the way files are located. See http://tldp.org/guides.html and
> look through the 'Linux Filesystem Hierarchy' guide, which is a more
> user-friendly translation of the 'Filesystem Hierarchy Standard' which
> is available from http://www.pathname.com/fhs/.
> Old guy
That's fine and dandy if all your assumptions are correct.
> Old guy
In article <5rof8sF15lcgcU2@mid.individual.net>,
Derek Turner <frderek@cesmail.net> wrote:
> Meat Plow wrote:
> Do I need to
> >> start my file manager as root? I seem to remember other distros having a
> >> regular file manager and then one with root privileges. I wonder if that
> >> could be the difference.
> when you find it (see above) use sudo gedit xorg.conf in a terminal to
> launch the editor in root mode.
Interesting thing is when I sudo gedit xorg.conf it opens it up and is
blank! If I just start gedit (sudo gedit) then go to file>open>xorg.conf
it opens as expected with all of the text. Strange.
brian wrote on Thu, 06 Dec 2007 13:20:21 -0500:
> blank!
Yeah, I suppose so if you really type sudo gedit xorg.conf (because then,
gedit searches for the file xorg.conf in the *current* directory).
It should open the correct file if you type sudo gedit /etc/X11/xorg.conf
Not really, see above.
Simon Gerber
simugerber@student.ethz.ch
Old guy
> Old guy
brian wrote:
> okay, I've hit google and a couple of linux (ubuntu) sites and for the
> life of me I cannot find xorg.conf file. It should be in the ~/etc/X11/
> folder but it's not (I did a search for it also). I need to edit it to
> use the Gsynaptics touchpad program. I'm using Ubuntu 7.10 with gnome
> (haven't change anything from a clean install from the livecd. Does
> anyone know where I might find it?
> tia
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
An excerpt from /etc/X11/xorg.conf on Ubuntu 6.06 LTS
> tia
# package.
> tia
# package.
> tia
# package.
Back
Top
